Use this procedure to view the LLDP port information.
To modify a value, double-click on a cell, and then select a value.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Select LLDP.
  3. Select the Port tab.
  4. View the administrative status of the port in AdminStatus.
  5. View whether the port is enabled for notifications in NotificationEnable.
  6. View the set of TLVs whose transmission using LLDP is always allowed by network management in TLVsTxEnable.
  7. Optional: Modify the TLVs as follows:
    1. To enable a TLV, select one or more values, and then select Ok.
    2. To enable all TLVs, select Select All, and then select Ok.
    3. To disable all TLVs, select Disable All, and select Ok.
  8. View the CDP administrative status in CdpAdminState.
  9. Select Apply to save any configuration changes.
  10. Select Refresh to verify the configuration.
Port Field Descriptions
Use the data in the following table to use the Port tab.
Name
Description
PortNum
Specifies the port number. This is a read-only cell.
AdminStatus
Specifies the administrative status of the port. The options are:
  • txOnly: LLDP frames are only transmitted on this port.
  • rxOnly: LLDP frames are only received on this port.
  • txAndRx: LLDP frames are transmitted and received on this port.
  • disabled: LLDP frames are neither transmitted or received on this port. Any information received on this port from remote systems before this is disabled, ages out.
The default is disabled.
NotificationEnable
Specifies whether the port is enabled or disabled for notifications.
  • true: indicates that the notifications are enabled.
  • false: indicates that the notifications are disabled.
The default is false.
TLVsTxEnable
Specifies the set of TLVs whose transmission using LLDP is always allowed by network management.
The following list describes the TLV types:
  • portDesc — indicates that the Port Description TLV is transmitted.
  • sysName — indicates that the System Name TLV. is transmitted.
  • sysDesc — indicates that the System Description TLV. is transmitted.
  • sysCap — indicates that the System Capabilities TLV. is transmitted.
The default is an empty set of TLVs.
CdpAdminState
Specifies the CDP administrative status of the port. Configure this field to true to enable the Industry Standard Discovery Protocol (ISDP) on a port. ISDP is CDP-compatible.
  • true: indicates CDP is enabled.
  • false: indicates CDP is disabled.
If CDP is enabled, the interface accepts only CDP packets. Similarly, if CDP is disabled but LLDP is enabled, the interface accepts only LLDP packets. To switch a port from CDP mode to LLDP mode, the LLDP status on that port must be txAndRx.
CapSupported(med)
Specifies the LLDP-MED capabilities supported.
The default is enabled.
